C5 Indicator switch
C5 Indicator switch
My indicator switch has a dodgy connection when I indicate to turn right. The problem only started recently. If I press hard it will work, otherwise sometimes it does and sometimes it doesn't. Have thought to dismantle to either i) check for dry joint somewhere, or ii) clean contacts with methylated spirits.
Took steering wheel shroud off and it appears that you have to take the airbag off to get any further. Didn't want to go any further with it without getting some advice first.
Has anyone else had this problem and is it easy to get access to the switch when you've taken the airbag off?
Cheers
Pete
Cheers
Pete
Current: C5 HDI Exclusive Saloon
Past : C5 HPI Exclusive Saloon
C5 HPI Exclusive Est
Xantia 1.9TD VSX
BX 1.7 TZD
Xantia 1.9TD VSX
BX 1.7 TZD
the COM2000 can be replaced easily by anyone,it only needs to go to the dealer if the car has ESP as the steering wheel angle sensor needs to be calibrated otherwise the ESP warning light will come on.SimonM wrote:Hi Pete, its the Comm2000 unit, its a known fault. Unfortunatley its sealed unit and a dealer only replacement as the unit has to be coded to the car. If your car is still under warranty get them to replace it.
Thanks for the advice, guys.
My car is a 2002 model so just outside the warrantly, however the main dealer is only half a mile away, so I may go and try to negotiate something with them. Will let you know what happens.
Cheers again
Pete
Cheers again
Pete
Xantia 1.9TD VSX
BX 1.7 TZD
Xantia 1.9TD VSX
BX 1.7 TZD
- mooseshaver
My indicator switch went just oustide warrenty. Can't quite remember the cost, but its was a huge amount for that little box and fitting.
I did try taking it to a non citroen garage, but when they rang for a price on teh part, they were told the car had to be reprogrammed for the new part. Stupid multiplex wiring.
I kept the old one incase the new one faisl and I can stop mechanical bits.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Multiplex wiring isnt stupid, the new COMM you have had fitted also wont fail, PSA changed the suppliermooseshaver wrote:My indicator switch went just oustide warrenty. Can't quite remember the cost, but its was a huge amount for that little box and fitting.
You cant blame the cars multiplex system for a cheap shoddy part fitted at the factory.
Ha Ha yeah right,the new ones aint much better.they are still giving indicator & airbag problems.PowerLee wrote:the new COMM you have had fitted also wont fail, PSA changed the suppliermooseshaver wrote:My indicator switch went just oustide warrenty. Can't quite remember the cost, but its was a huge amount for that little box and fitting.
Disconnect the battery, Wait 5 minutes. remove the airbag & the steering wheel. Carefully note the position of the steering angle sensor (look for the white pointer). then remove the comm switch
The comm switch is not sealed & can be opened by carefully prising the retaining tabs. Clean the affected contact wipers & the pads on the pcb. Then relubricate the cleaned contacts with some of the surplus grease from other contacts. Carefully reassemble and all should be well.
To remove the steering wheel. First remove covers from the steering column
They are retained by screws which are removed from underneath. They have either phillips or Torx heads I cannot remember. If you then look in at the back of the steering wheel you should see 2 openings within which you shouldsee the wire clips or loops which retain the airbag. If You or an assistant presses & releases the centre of the wheel (operating the horn switch) you should see them move. Use a screwdriver as a lever to release them. The airbag will come away from the steering wheel. Carefully note the position of tthe wires & then remove them. The steering wheel is retained by 1 nut. I cannot remember if there is a master spline so mark the position of the wheel relitive to the steering column just in case. The wheel should then pull off but may need some not so gentle persuasion
Thanks once again svesey. To get back to your original post, when you talk about prising apart the comm switch presumably you are talking about the part underneath the air bag and not one of the operating stalk ends(otherwise why remove the air bag)
I only mention this because my problem seems to lie with the button on the end of the wiper stalk not operating the trip computer. Do you think cleaning the contacts as you suggest would go anyway to solving this problem?
(I have just been quoted £317 to supply and fit a new comm unit - £144 for part - £126 labour - +vat)
I only opened one comm switch & that was because of intermittent operation of the indicators similar to that described in the first entry on this thread. You operate the switch & notice as you turn that the indicator didn't operate. Next time it works perfectly. As far as I remember the contacts for that button are at the end of the stalk & are connected to the pcb by wires fed down through the centre of the stalk. I havn't dismantled either stalk so I do not know how to go about it. Sorry I cannot be of more assistance. I really should have taken pictures of the dismantle-reassemble process in case they were of use to someone but at the time all I wanted was for the indicators to work. This was several months ago and so far so good. Many of the so called unrepairable units are indeed repairable with care. eg BX light switch, electric window regulators on XM & Xantia, certain faults on th C5 COMM unit
