ZX 5 door tailgate lock
KEB1
Unread post by KEB1 »
Hi All,
I have got to replace the tailgate lock on my ZX 5 door hatch with CL because the lift tag has broken of.
The BOL states that the rear wiper motor assembly must be removed first to allow the lock to be replaced.
However, looking at it, I think that there is enough room to replace it without removing the motor.
Has anyone done this job ?
All the best,
Kristian.
1993 ZX 1.4i Aura
1984 2CV6 Club
1972 Dyane 6
Past Citroens
1975 CX
1972 GS Club
jeremy
Unread post by jeremy »
If you only want to remove the outer plastic lock/tag bit its very easy. Open tailgate, remove plastic cover and you will find thet the plastic lock/tag is held in with a metal clip which runs in slots top and bottom of the lock. You can either pull it out by hand or tap it out with a length of wood or something.
Refitting as usual is the reverse.
jeremy
KEB1
Hi Jeremy,
Thanks for the info. I thought it did look possible, but the BOL seemed to indicate otherwise.
I shall be doing the job asap.
All the best,
Kristian.
1993 ZX 1.4i Aura
1984 2CV6 Club
1972 Dyane 6
Past Citroens
1975 CX
1972 GS Club
