C5 Brake Squeal
Bill Black
C5 Brake Squeal
Unread post by Bill Black »
This is probably a daft question, but can somebody explain why some cars have terrible brake squeal whilst others don't. My hitherto faultless 2003 C5 is starting to develop a really annoying squeal on normal smooth braking from about 10 mph to rest, especially in hot weather. There's plenty of wear left on the pads and discs so the dealer's not prepared to do anything, even under guarantee. Comments...
Cheers Bill
Ex: 2CV, Ami Super, CX 2.2TD, Xantia & C5
(Should've learnt by now shouldn't I ;))
PowerLee
Unread post by PowerLee »
Most likely they just need the dust blowing out, A clean up of the caliper & some copper grease on the back of the pads & the sliders & stick it all back together :wink:
Kowalski
Unread post by Kowalski »
Is this the first case of a C5 getting the same squeal that Xantias used to get?
The C5 rear calipers are of a similar design to the Xantia ones, so it would not suprise me if it gets the same problem with corrosion behind the calipers.
Bill Black
I've never had brake sqeal on any of my Citroens in fact. Have I just been lucky? My old '75 Opel Kadett, '81 Escort & '83 VW Passat all suffered from it from time to time, but the sqeal I'm getting now is terrible. Bad enough to cut my losses and get rid of it.
Cheers Bill
davetd
Unread post by davetd »
Hi Bill
The rear brakes are load sensitive on hydropneumatic citroens, so an unladen car doesn't really give them much work to do. :roll:
It's the same as a conventional car that just does just town driving.
The more weight in the back, the more work the rear calipers have to do.
So the lack of use causes them to seize.
Change the rear pads and dismantle and lube up the calipers.
davetd
93 Xantia SX TD Manual Metallic Grey 145,000 Non Anti-Sink
KevMayer
Unread post by KevMayer »
I believe the brakes (and power steering) on a C5 are conventional like on the Xsara etc. So, the rear brakes aren't load dependant like on a Xantia.
Cheers, Kev
Cheers, Kev
davetd
Oops :oops:
KevMayer
Davetd,
I didn't realise the brakes and power steering is conventional until I purchased my C5 so I don't think you're alone in thinking the set up is still like a Xantia.
cheers, Kev
Cheers, Kev
