Solid Rear End
fatbugger
Solid Rear End
Unread post by fatbugger »
Hi All
I need help (or so my wife and friends say)
T reg Citroen Xsara 19.D. Rear suspension has gone rock solid. Have been told it could be rear swinging arms that have seized? Are these fixable or is it much of a job to replace? Sounds horrendously expensive.
Any advice would be most welcome
Mike
2005 Peugeot 407 SW SE 1.6 HDI 110 BHP
1998 Peugeot 406 SX TD Deceased
1999 Xsara Sensation 1.9D Deceased
x 1431
Yeah, sounds like one of both of the trailing arm bearings has seized - never heard of it before - have you parked it in the sea or something?? Easy way out is going to be to fit another subframe. It's basically the same for the ZX, 306 and Xsara, so getting another one shouldn't be too hard - just make sure it's not off a lowered car, and it's right for hatch/estate, and is fitted with the right brakes. Fit new mounts whilst it's out! Should be DIY-able in a day.
Mandrake
x 694
Unread post by Mandrake »
opps, reply deleted....
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
mezuk04
Unread post by mezuk04 »
Were Xsara's ever fitted with spheres?
Volkswagen Golf 59' 1.6TD S :(
Mandrake
x 694
mezuk04 wrote:Were Xsara's ever fitted with spheres?
Doh. Didn't even notice he said Xsara. Thats 2 out of 2 wrong for me today :(
Regards,
Simon
Simon
1978 CX 2400
Clogzz
x 40
Unread post by Clogzz »
Can't see a reply as such to that, :? but the answer is no.
The Xsara has only ever had metal springs and shock absorbers.
2002 C5 2.0i AL4 239,000 km 76372389
wrinklet1
Unread post by wrinklet1 »
i the xsara trailing arm the same or similar to the xantia? if so, you should be able to replace the bearings on it
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
AndersDK
Unread post by AndersDK »
wrinklet1 wrote:i the xsara trailing arm the same or similar to the xantia? if so, you should be able to replace the bearings on it
Not quite -
Its a 3 torsion bars design - 1 for suspension each side - and 1 acting as ARB. To me it looks pretty jobby to replace the bearings.
0500 03 422105 SUSP CROSSMEMBR TORSION BAR RECESS DOOR MOTEUR TYPE XU/XUD ET BERLINE ET SUSPENSION NORMALE SAUF INJECTION XU10J4RS
http://www.citroen-pr.net/catalogues/il ... 221050.gif
Anders (DK) - '90 BX16Image
