jgra1 wrote:i have taken the rear half of it apart
in this order.>
dust cover,
8mm nut
metal outer ring
Diaphragm
flat plate
spring
spring clip
metal disc
That order doesn't seem right...what is the "flat plate" you refer to ? (Perhaps you could take a picture with the parts laid out in the order you think they go on ?)
Counting from reverse order (from the middle of the height corrector body outwards) you should have the spring first (with the small diameter side facing inwards to the body from memory) then the round washer, then the circlip to retain the washer.
Is this not what you have ? Looking at the height corrector from the outside after removing the rubber diaphram you should not be able to see the spring - it should be hidden underneath the small round washer/disc, if you've got the spring outside of this washer it's definately assembled wrong.
The springs under the washers (on each end) push the washers outwards until they press against the circlips, and the balance of spring tension between the two equal springs is what moves the height corrector shaft (via the circlips) to the middle (closed) position when no force is applied to the shaft.
Regards,
Simon
PS that website with the DS info on it appears to have the "old" style DS height correctors, which have significant internal differences and aren't the same as the modern ones...Doublechevron would know more about the differences between the old and new types so hopefully he will chime in..
