306 td estate...few questions
saracen480
Unread post by saracen480 »
Hi all, new to forum and pugs in general (volvo man.....old 480s with the renault block)
anyways....just picked up a nice 306 turbo diesel estate - 98, s reg.
few little niggles...things like wing mirrors need replacing, but mainly what i wanted to ask is what are the main things i need to do to make sure it keeps running ok....as in initial big jobs, not just things to keep it ticking over..
its got 71k on clock, and has just had the cam belt done at 70k....
ive heard some stories that they can be expensive to maintain, but i do most of the servicing on my other cars myself, so im pretty hadny. (iv got volvos remember....costs 20 quid to TALK to a dealer, let alone buy anything!)
thanks in advance
rob
matt
Unread post by matt »
Welcome to the fold!
Im sure you won't be dissapointed with your purchase,as you say the main thing is the timing belt has been done,only other thing ive heard is that the head gasket goes every 120 000 miles or so,but i wouldnt worry about that yet.
My 405 is at 186 000 at the moment and all i do is change the oil/filter/air filter every 6,000 miles,then fuel filter every 12,000 miles,this costs me the grand total of approx £26 from GSF so it really is cheap to maintain.
I suppose it won't hurt to keep an eye on suspension bushes and the like but that depends on how bothered you are.
The only major problem i have found with pugs is the rear beam(worn radius bearings etc)other than that i swear by my 405.
Good luck!
92 205 1.9 GTI(MODIFIED,SORRY )
1996 VOLVO 850 2.5 5CYL 10V
1999 EXPERT VAN TD - WHITE !
No more car's thanks!
saracen480
cheers matt.
i had noticed a bit of a front end shudder when braking from speed....just reading round the forum and it seem like this could be wishbone bushes....
(just like youve mentioned)
top stuff......thanks for the advice dude.....
once i get the standard stuff done, am going to think about increasing hp, maybe an atmos DV, boost gauge etc....but want to see how reliable just yet!
cheers
rob
DirtyGertie
Unread post by DirtyGertie »
Welcome to the world of Pugs :)
Have you got the letters DHY in your vin plate? if so i heard that disconnecting the EGR and regular oil changes and maybe the odd engine flush will help to keep the engine in one piece there have been some conrod failures :shock:
PowerLee
Unread post by PowerLee »
Its the April 1997 to April 1998 306 1.9 turbo diesels with the DHY coded engines that go bang.
The 306s with the DHX engines from the same time period are fine.
rossd
Unread post by rossd »
I didnt think the 306 ever got the DHX, that was 406, 806 etc? The DHX is the one with semi-electronic control is it not?
I would disconnect the evil EGR as a matter of course to be honest, regardless of the engine type. Done it on both my HDi's and they run the better for it! :D
2003 Xsara HDi 110 - Commuting Hack
http://www.rossy.org.uk/ - 205 Track car progress
pugxpert
Unread post by pugxpert »
yeah i would agree with you there dhx in the 406 806 dhy is in 306 with the cat and egr s*it
EP6T petrol turbo nice engine in the 207 GT and the new mini....
