xsara 2001 engine mount
johninderbyshire
Any ideas how much i should pay for the bottom engine mount to be replaced on my 2001 mk2 xsara?
Clogzz
- x 40
Say that this is filling in until the experts arrive.
Looks like there are 12 different ones, depending on the model.
For some, you may get the rubber only.
For others, it's the entire casting for big bikkies.
You may get the rubber only for all of them from Peugeot.
0501 01 348001 FIXING POWER UNIT INJECTION TU3JP UNTIL RPO No. 09801
0501 01 348001A FIXING POWER UNIT INJECTION TU3JP SINCE RPO No. 09802
0501 01 348010 FIXING POWER UNIT TU5JP4 INJECTION AND BVM
0501 01 348015 FIXING POWER UNIT TU5JP4 INJECTION AND BVA
0501 01 348020A FIXING POWER UNIT INJECTION EW10J4 AND BVM
0501 01 348020L FIXING POWER UNIT INJECTION EW10J4 AND BVA
0501 01 348030A FIXING POWER UNIT INJECTION XU10J4RS
0501 01 348050A FIXING POWER UNIT DV4TD TURBO DIESEL
0501 01 348060A FIXING POWER UNIT DW8B DIESEL AND EEC 2000 DEPOLL (ENGINE)
0501 01 348070A FIXING POWER UNIT TURBO DIESEL DW10TD
0501 01 348071A FIXING POWER UNIT DW10ATED TURBO DIESEL AND BVM
0501 01 348072A FIXING POWER UNIT DW10ATED TURBO DIESEL AND BVA
2002 C5 2.0i AL4 239,000 km 76372389
johninderbyshire
its a 1.4 petrol that i have. I hope its the rubber only. The car has done 83000 miles now and apart from this "noise" i have when i pull off everything is fine. The engine moves quite a lot, and the brother in law is putting a big bet on this engine mount being knackered. I have a knowledge of mechanics but this car has been a pig of a car and everything that goes wrong is expensive to fix
let alone being quite a challenge. The easiest thing was the anti roll bar link which took ten mins
AndersDK
Fiddly job -
Either you remove the lower engine support bracket (10min's) and hacksaw out the old bush (upto 30mins), pressin a new bush (20mins) and refit bracket (5mins). Some 1hour total plus som £10 for a new bush.
Or - you dismantle RHS suspension arm/hub, remove RHS driveaxle, remove lower engine support bracket, remove engine support mount, refit new engine support mount, refit the rest - at least 3-4 hours plus the expensive complet mount assembly.
Anders (DK) - '90 BX16Image
johninderbyshire
f00lzz
So! that would be 3-4 hours labour plus parts. Different garages, different labour rates.... like asking how long is a piece of string.AndersDK wrote: at least 3-4 hours plus the expensive complet mount assembly.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Clogzz
- x 40
How about saving big bikkies by doing it yourself, using an old shoe like this crazy Frenchman:everything that goes wrong is expensive to fix![]()
http://www.bxclub.co.uk/forum/viewtopic.php?t=2046
johninderbyshire
well this "noise" has turned out to be something more serious!!! After i posted, i went out and the temp gage went sky high and the stop light came on. Drove home and noticed it was low on water, so filled up the water and left it overnight. Got in the next day and before i got to the end of the road, the temp gage was high again and the stop light came on again. Anyhow, rang my mechanic and told him about the noise when pulling off and the temp problem (ruled out the rad thermostat) he seems to think its the cylinder head gasket and quoted £300!!!!
It makes sense as for about 6 months when i first start it in a morning it often cuts out and sounds very "blowy" untill it is warm and then it seems ok. No smoke, no water in oil but now with temperature problem and its definately not the rad thermostat as i have replaced it today.
