Just idly mulling here...
Would I have to reinvent the wheel some, if I got hold of a HDi diesel Xantia engine and dropped it into a TD one that needs a new engine?
I'm totally up for it and would like to hear any serious and or constructive suggestions/tips/must do's and dont's etc...
Has anyone seen it done or carried this conversion themselves?
Andrew
Xantia diesel swap
jeremy
The HDi will need a high pressure fuel system with a pump near the tank - and the electronics may well be fun - OK if you get all the bits from a donor car - but getting them one at a time may not be quite so easy.
I would also expect there are numerous little bits that will frustrate you and make an apparently simple job look like your life's work.
jeremy
AndersDK
- x 1239
Rostami
I know both engines well...It would be quite a job. not really a drop-in replacement. Plus, as has been said, the electronics will cause you many headaches. If you are willing to change the whole engine bay and put in an HDi dashboard, then this would make it easier on you.
I would go for the 2.1TD engine. The HDi is really a very mice and smooth engine, and consumption is lower than 2.1TD but even so I am not quite sure if worth the effort!
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
andmcit
- x 30
OK, thanks for the input guys, maybe I'll stick with the quest for a 1.9 or 2.1 instead of the HDi I managed to find!!
I've got to ask!! Will a conversion from Xantia 1.9 to 2.1 require 'just' the alternate manifolds/aircleaner assembly etc... Surely both set ups use the pull system of fuel feed and electrics are just down to the fuel cut off!? Right!!??
Fortunately, I've not had THAT much dealings with the 1,9 TD lump in mine; the usual oil changes and pump resuscitation etc...
Thing is, I've neither had much to do with my Xm's 2.1, yet...
Andrew
Andrew
- x 1239
andmcit
- x 30
- x 1239
Ah right, well that could cause another problem. Is your 1.9 electronically managed, does it have a 'fly by wire' throttle cable or is it connect to the pump? Most of the 2.1s about are mechanical from XMs, you really need one from a 406. Of course if you could get one from a Xantia that would be nearly perfect, but there ain't many of they about.
