Electronic speedo module
DaveW
Unread post by DaveW »
Does anyone know if the electronic speedo module fitted to the Xantia TD has been used on Peugeots using the 1.9 engine unit.
If it is/was used on these, what model(s) used that engine.
Mine has quit and, as I live out in the sticks (nearest reasonable breaker is 50 miles away) I'm trying to locate a S/H one.
Dave.
Xantia Forte 1.8i, 16v X reg.(09/2000) 93K, aircon
Clogzz
x 40
Unread post by Clogzz »
Bump.
This may be the speedo sensor fault on the gearbox housing:
http://www.citroencarclub.org.au/forum/ ... php?p=8537
Can anyone elaborate on this, or dig up relevant topics ?
Dave, has the PM arrived ?
With inbox, outbox and sentbox, I'm no longer sure of what I did. :?
2002 C5 2.0i AL4 239,000 km 76372389
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
small chance it could be the plastic drive in diff housing.. mine went recently after a driveshaft removal/refit..
£1 part.. if you pull speedo drive out you may be able to detect rotation (or not) of metal worm drive driven by this plastic item.
(roll car forwards a meter and feel if it turns?)
where in West Sussex are you? out of interest
John
jgra1
(Donor 2021)
x 36
oops wrong Dave
ignore West Sussex comment
DaveW
I had checked the connections and they were pristine.
It was just that breakers are thin on the ground around here and it would have been useful to know if it was a common part to both Citroen and Peugeot. (for me and others who frequent these boards)
I have now managed to get a S/H module (£5) and all is working again.
Dave.
