On the old Xantia i had the normal problem of hard front suspension which i fixed but the problem with the suspension on the new one has got me a bit miffed. Ive done a search and im thinking height corrector stuck and accumilator sphere gone, but ill run thru my symptoms and see if im wrong lol.
1. When you start the car the Drivers side rear drops suddenly and then goes back up (only drivers side)
2. Rear Does not raise or lower when you use the height control (front moves but i dont think it goes to max as you can see the suspension strut thinky stuggling)
3. No give in rear, suspension is rock hard at the back
4. Clicks every 10-20 seconds (should be 30+?)
Apart from that its a very good car. my wife loved her old xantia so i bought her a new one for her birthday, just need to fix it now
