Smoke from Xantias seats.
Quackers
x 17
Unread post by Quackers »
Was in traffic yesterday and smoke started coming from the passenger seat, foul electric smoke :shock: Its a 3.0 V6 R reg Xantia Exclusive, it has electric seats, but not heated. Now the very front of the seat (where the back of the bottom leg are near when sitting on it was VERY warm.
Stopped the car, turned the power off, it stopped smoking. It did it again on the way back, after about 1 hour to 1 hour 30 mins of driving. I have resorted to pulling fuse F13 out to disable the chairs, as after a few minutes you can feel it getting warm.
Has anybody experienced this before? Any ideas before i have a closer look tommorrow.
AndersDK
Unread post by AndersDK »
Seems like a motor is working against an endstop. Bit weird as they should have thermal fuses build in. Could also be a low-ohm path in a faulty motor acting as a heating element - just barely NOT burning the fuse.
In any case check the fuse is as rated by Citroen. Too heavy fuses are potiential fire hazards - as you know now :?
Xantia :
0291 05 502201 BELT AND SEAT HARNESS CDE SIEGE AV ELECTRIQUE
http://www.citroen-pr.net/catalogues/il ... 022010.gif
XM Mk2 :
0271 05 502202 BELT AND SEAT HARNESS DEPUIS OPR 07329
http://www.citroen-pr.net/catalogues/il ... 022020.gif
Anders (DK) - '90 BX16Image
Richard Gallagher
Re: Smoke from Xantias seats.
Unread post by Richard Gallagher »
Quackers wrote:Its a 3.0 V6 R reg Xantia Exclusive, it has electric seats, but not heated.
Not wishing to doubt you, but are you sure it doesn't have heated seats? AFAIK all Exclusives had them as standard.
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
Quackers
x 17
It was only standard on Exclusive from 98 onwards. This ones 97. Also there is no button for the heated seats.
f00lzz
Unread post by f00lzz »
Yes! I believe it was a 'winterpack' option. Same with the headlight washers!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
PowerLee
Unread post by PowerLee »
AndersDK wrote:Seems like a motor is working against an endstop. Bit weird as they should have thermal fuses build in. Could also be a low-ohm path in a faulty motor acting as a heating element - just barely NOT burning the fuse.
XM Mk2 :
I would check the switches for the electric seats.
These are prone to sticking & causing problems.
Never heard of a thermal fuse being built in to the electric seats.
Then again ive never heard of a thermal cutout being built in to the heated seats either!
AndersDK
PowerLee wrote:Never heard of a thermal fuse being built in to the electric seats.
Me neither - but found in electric motors - as I wrote above. Exactly to prevent fire hazards.
Homer
x 16
Unread post by Homer »
If it has heated seats it will have two thumbwheels, in the center console near the gearstick.
Quackers
x 17
XM Mk2 :
I'm suspecting the button sticking, as when you start the engine the "pump up the seat" noise comes on straght away, as if the button is stuck on pump. Been at work all day + rain, not been able to play! :x
