Richard you are right there is nothing but windscreen wiper wiring immediately below the windscreen, I've spent most of the day dodging the rain checking things out checked out fuse box nothing wrong as far as I can see.
Pulled plug under carpet by drivers door to disconnect the whole of the rear light/ central locking/ screen wash /wipe/ heated rear window to exclude faults there. There is 12V on the bulb side of the stop light sw which with the sw disconnected there shouldn't be (I think
) If i pull all the live feeds from the fuse box there is still 12 V there. I then pulled the large value fuses under the bonnet, The haynes Manual does not identify them there are 2 a 60A and an 80A that both have to be disconnected to lose the voltage on the brake pedal switch.
I then checked for continuity from the brake pedal bulb side and found that with the ignition sw connectors dis connected there was continuity between 2 of the feeds from the battery to the ignition sw and the bulb side of the brake pedal wiring so it seems as if there is a short between the feed from the battery and the lead from the brake pedal sw to the multiplug by the drivers door which seems very odd, the only unknown being that the ABS (No wiring diagrams at all in Haynes for that little can of worms
)which works fine is connected somewhere along that piece of wire. Next up is to look at the harness where it crosses the front of the car under the rad, presumably taking the supply form the battery /fuses to the drivers side inner wing and so through to the fuse box.
If only I could get that Lasertec Manual to work I might have some decent wiring layouts to work from
________
Suzuki gsx-r1000
