Peugeot 406 1.9dt R reg engine fault
rich201283
My engine has sudenly lost power, losts of smoke and sounds like it missing, I have checked engine sensors, Put it into peugeot and it came back with a fault with the pump, Got a 2nd hand pump put it on(same problem) What i did notice there was a lot of oil gunge in the inlet manifold, iTS NOT OFF THE TURBO AS THIS IS OKAY, I think its a valve or a piston ring
Anybody had this kind of problem with valves or rings?
pugxpert
fastandfurryous
- x 4
rich201283
I had the fault code read by peugeot and it came back as , start of injection fault, I have noticed that when i flick the ignition key off then on while its running it wil rev up as normal an the is will go sluggish and smokey and the k light comes on, it cant be the fuel pump coz i have put another one on,
I have thought it may be a relay or ecu since when i flick it on/off while running it revs up ok for a second
ANY IDEAS IF A BLOCKED CAT WOULD CAUSE THIS PROBLEM???????
My second option would be rings
ANY IDEAS ON THIS AS IM AT THE END OF MY TETHER WITH I?
Regards Lee
Regards Lee
Dave Burns
- x 3
rich201283
fastandfurryous
- x 4
fastandfurryous
- x 4
That's fairly irrelevant, as the rev-counter has it's own sensor on the flywheel. (I believe)rich201283 wrote:i have unpluged the crank position sensor and the lift sensor on the pump one at a time and the rev counter still works,
no, and no. The inlet manifold is caked in goop because of your spawn-of-satan EGR valve.rich201283 wrote:I will say that the car was overfilled with oil about a year a go, would this have cause the oil in the inlet and blocked the cat over time, ?
If you can unplug the needle lift sensor from the injection pump, and there's no difference in the running, then you have found your fault. Unplugging this sensor should make the engine run rough-as-nuts. It's already running rough-as-nuts, and unplugging the sensor makes no difference..........
This is not a signature.
Dave Burns
- x 3
When you say "lift sensor on the pump" I assume you mean the injector lift sensor.
What did you notice (if anything) about the engine note when each of these sensors were unplugged.
What happens when both are unplugged.
Overfilling with oil is unlikely to cause you problems a year down the line, any problem should have been aparent there and then, there might have been some misting and this might have put some oil into the intake, but it wouldn't have gone down the exhaust in that form because it has to go through the cylinders, and there it would simply have burnt.
Dave
Dave
rich201283
reblack68
pugxpert
start of injection,ecu will calculate what advance is required at a given engine speed and load and will adjust advance regulator in pump,then it will look at needle lift signal on injector to confirm actual advance .if out will correct but will only correct so far if way out of its limits will record a fault.check your timing belt is set and all locking pins fit in cam and pump when at tdc. your pump is adjustable on its fixings you should have 0.66mm lift on pump at tdc this is then set correctly(dti in back of pump). if that all ok then check wiring to injector and injector. your injector i think should be in cylinder no 3.
EP6T petrol turbo nice engine in the 207 GT and the new mini....
fastandfurryous
- x 4
THIS IS YOUR PROBLEM!!!!rich201283 wrote:When i unplug the lift sensor on the injector it runs the same,
I don't think that static lift measurement is valid on a Lucas EPIC system.pugxpert wrote:your pump is adjustable on its fixings you should have 0.66mm lift on pump at tdc this is then set correctly(dti in back of pump)
After all, the whole reason that the system was introduced was to avoid the need to time the pump to the engine. You just shove it on in roughly the right place, and the electronics deal with the precise timing. Cheaper to use a box-o-electronics than it is to pay a man to time every engine that's manufactured. The electronics probably cost peanuts to the manufacturer, and save them many many man-hours.
pugxpert
only the 2.1 dt had the lucas epic system. all the 1.9 td have the bosch vp20 system which is like a normal injection pump but with electronic advance control.this bloke has a 1.9 td and you do have to static time the pump if it has been removed
rich201283
