1996 R19 with starting problems
NiSk
Unread post by NiSk »
Got called round to a friend who's R19 "stalled" in traffic and then wouldn't start. He got the villiage mechanic to look at it - so it then started OK, he went for a (short) drive and it stopped again. Now it won't start at all. The mechanic recommended a workshop in a nearby town with a SUN diagnostic machine.
The engine cranks at normal speed, no problem with battery, compression sound while cranking, cam-rem/camshaft intact, strong smell of petrol after a few minutes cranking.
Haven't checked any voltages yey, I didn't have a meter with me at the time.
Is this model known for such faults? What should one look at to start with?
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
Stuart McB
Unread post by Stuart McB »
Coil pack or coil packs. have a look and possibly change. Reno have terrible coils on their 1.6 magane engine. So could be the same kin of thing.
The wifes got a C4 I've got a ZX TD SX!!!!
NiSk
Well, a quick check with a multimeter showed 12 Volts in, pulses from the flywheel sensor, but no spark from the HT output.
We picked up a new coilpack from a scrappy and fitted it - Hej presto! working again!
Thanks for the tip.
//NiSk
Stuart McB
Glad it helped. :D
