Manually turn off xantia alarm?
LeeDJC
Unread post by LeeDJC »
After disconnecting my battery yesterday,my alarm keeps going off every time you open the door or start the ignition. I've turned of the siren, so it's quiet, but the headlights keep flashing.
My plip doesn't work either :(
Is it possible to manually deactivate the alarm, or will I need to sort out my plip first?
Cheers
2004 Berlingo Multispace HDI, 105000
mezuk04
Unread post by mezuk04 »
Cant you pull the fuse out from your knee area......thats what I did as Im not a big fan of alarms.
Volkswagen Golf 59' 1.6TD S :(
LeeDJC
aaah, didn't think of that ;)
It's in the garage having a balljoint done at the min. Will do it when I get it back. Cheers :)
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
;) my 95 TD used to do this after a battery disconnection..
try taking batt pos terminal off, then putting ignition on, and reconnecting terminal;;
that should fix you :P
John
DaveW
Unread post by DaveW »
The procedure is :
Open the door, press and hold down the alarm button (on my car, the furthest right of three buttons to the right of the steering wheel), put the key in the ignition and turn it fully.
Once you have turned the key, continue to hold the button down until both 'turn' lights stop flashing.
You have, I think, 10 seconds from when you open the door to complete the sequence or you have to try again.
Dave.
Xantia Forte 1.8i, 16v X reg.(09/2000) 93K, aircon
LeeDJC
DaveW wrote:The procedure is :
Dave.
Sweet - worked a treat. Thanks!
