xantai clarion radio problem
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
All, I have put my original clarion back in my xantia.. it was working perfectly when removed. It is one of the models fitted to Mark 2 xantias, with cd changer capability. It came straight up with the 4 central dashes. I pressed and held BAND and 4 more dashes joined those, underneath.
I left ignition on first position for 50-60 minutes and the CODE did not come up, then the BAND button gave the same 4 extra dashes...
Also, the flashing red light never came on (But this may be related to the radio not working)
what can i do? seems odd its gone wrong while out of car doing nothing :(
John
jgra1
(Donor 2021)
x 36
no one think of anything? :?
John
jgra1
(Donor 2021)
x 36
I guess i will just try it for more than 1 hour....
f00lzz
Unread post by f00lzz »
Why did you hold the 'bnd' button?
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
f00lzz
Switch back on... with 4 dashes showing, type in code No. radio will start up automatically.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
jgra1
(Donor 2021)
x 36
it needs to come up with CODE before i can type :(
casso
Unread post by casso »
I had a problem like this when a incorrect code had been entered (several times) and the radio "locked". Advice from this forum suggested leaving it on for several hours until "code" was displayed. I removed radio and rigged it up with a spare battery in the the shed. I left it for three days (checking it twice a day) and was about to give up on it when eventually "code" appeared. I entered the correct code and it has been ok since. Good luck.
jgra1
(Donor 2021)
x 36
god!!
thanks Casso!!!
I thought an hour would be enough ;)
will do as you say
f00lzz
On the Clarion set you only have to press the BND button to reset... then type in the code!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Gregg1100
x 5
Unread post by Gregg1100 »
Will this help you:
http://img.photobucket.com/albums/v676/ ... iocode.jpg.
Supplied to me by a kind member of this forum
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Gregg1100
x 5
Clarion Radio Code
Seems link didn`t work.
Try this time :
Greg
jgra1
(Donor 2021)
x 36
Simon many thanks but i have the manual ;)
but you cant enter a code unless CODE is there first ;)
the stereo is U/S :(
i may take the earlier advice and leave it hooked up for days and wait....
annoyingly, it came from my car and never ha a bad code entered so it shouldnt have gone into this stupid security mode anyway ;) i think i should throw it :D
jgra1
(Donor 2021)
x 36
Greg I mean !! (champions league final has left me under par ;) )
rpaco
Unread post by rpaco »
casso is quite correct!
I had the same problem, and also had to leave it hooked up for more than 3 days before CODE appeared again!
Each time you press band or turn off, the countdown starts again.
If you take it out of the car, you need to keep the main AND the memory terminals BOTH hooked to 12V+ and the casing (or the -ve terminal in the ISO block) to the -ve pole of a spare battery or other continuous 12V power source.
In my case my car batt was too low to leave it on the ACC position for 3 days. (Turning the radio on without the key being either in the ACC or IGN position runs the radio for about an hour then it turns itself off and you start the countdown again)
There is a long thread about this from a few months ago. The handbook is totally wrong when it says you only need to leave it for 1 hour.
jgra1
(Donor 2021)
x 36
thanks again very handy
An earlier version of the unit did only need an hour, but it seems these need more..
Think i will leave it on all weekend with spare key and cover the red light on dash. Will pop charger on every day :)
