306 HDi Problem
chris171280
306 HDi Problem
Unread post by chris171280 »
My mate has a 306 2.0L HDi on a Y plate, its only done 17 000miles with fsh and hasn't been thrashed or raced (apart from the odd occasion i've borrowed it), She's only had it for about 6 months but before that it was her mothers from new. For the last few weeks its been a little smoky but has got a lot worse, power is way down and sometimes she struggles to pull away without stalling it. She's worried its going to cost a fortune to fix so i'm going to have a look at the weekend, a few people have suggested the Cat could need replacing but i know nothing about them, the problem seems a little extreme for it to be that. Other suggestions have been the Turbo, MAF, Injectors, Fuel pump over fueling.
I figure i'll start with the MAF, Is it the same as my PD Diesel? ie if I disconnect it will the car drive better without it if this is the problem?
Some of the things i've been told seem very unlikely for a car of this mileage so any help/idea's would be greatly appreciated.
Cheers People!
howiedean
Re: 306 HDi Problem
Unread post by howiedean »
chris171280 wrote:My mate has a 306 2.0L HDi on a Y plate, its only done 17 000miles with fsh and hasn't been thrashed or raced (apart from the odd occasion i've borrowed it), She's only had it for about 6 months but before that it was her mothers from new. For the last few weeks its been a little smoky but has got a lot worse, power is way down and sometimes she struggles to pull away without stalling it. She's worried its going to cost a fortune to fix so i'm going to have a look at the weekend, a few people have suggested the Cat could need replacing but i know nothing about them, the problem seems a little extreme for it to be that. Other suggestions have been the Turbo, MAF, Injectors, Fuel pump over fueling.
Cheers People!
1st thing I'd start with is the fuel filter and air filter.
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
chris171280
Hi
Been and had a look today the filters are ok, when driving the car if i didn't know it was a turbo i wouldn't know something was wrong, i can hear the turbo spooling up just before 2000rpm but there is no power from it, so it looks like it might be the turbo, will a diagnostic check prove or disprove this or is there another way to tell?
Cheers.
AndersDK
Unread post by AndersDK »
Like you said "Some of the things i've been told seem very unlikely for a car of this mileage" - exactly what applies to the turbo. The turbo unit itself is extraordinary reliable.
Find a local diesel specialists garage near you - not a Peug dealer. Let them have a diagnosis. My guesstimate is that the injectors could be carbon fouled. Which is not overly expensive to correct.
It may even be cheaper than you buying parts swapping to try find the problem.
Anders (DK) - '90 BX16Image
TomH
Unread post by TomH »
needs a good thrashing by the sounds of it :wink:
saxoqueen
Unread post by saxoqueen »
I may be wrong here but I have a 2001 306 HDi and it DOES NOT have a Turbo fitted! According to Pug they never fitted turbo's to these engines - the 90BHP version. The later 110BHP 307's had an intercooler fitted but seems was never an option on the 306. Why the heck PUG ever stopped the 306 still baffles me (and some of the guys at the local Pug dealership!)
Cheers,
Anne
PowerLee
Unread post by PowerLee »
The 306 HDI 90 BHP DOES have a turbo fitted.
saxoqueen
As I own one of these, would you kindly tell me where it is? Cos Pug dealer can't find it !!
Cheers,
Anne
PowerLee
The turbo charger will be on or in the exhaust manifold.
The part numbers for the 3 different turbos that where fitted by Peugeot to the 306s DW10TD lump are 0375 E0, 0375 E5 & 0375 H7.
fastandfurryous
x 4
saxoqueen wrote:As I own one of these, would you kindly tell me where it is? Cos Pug dealer can't find it !!
Then your pug dealer is a complete and utter waste of time (what's new there?)
The 90BHP HDI engine has a turbo but no intercooler. The 110BHP has both a turbo and an intercooler.
This is not a signature.
saxoqueen
Ok many thanks for clearing that one up. I've given up on the local Pug dealer after my daughter took her 206cc back 5 times for a leaking roof/door and it still leaked! Took it to another dealer and they sorted it out in a couple of hours!
Where in the rev range is the turbo set to kick in or is it there all the time?
Cheers,
Anne
fastandfurryous
x 4
saxoqueen wrote:Where in the rev range is the turbo set to kick in or is it there all the time?
To understand the answer to that, you need to understand how a turbo works. Whilst it is "there" all the time, it only provides pressurised air when there's sufficient energy available in the exhaust stream.
This is on the HDI 90 engine. On the HDI 110 the wastegate is controlled by the ECU, so the turbo can have a set rev range.... but again, only when the turbo is within it's operating RPM range already.
ACTIVE8
x 6
Unread post by ACTIVE8 »
Well, so much for the main dealers expertise, and specialist knowledge. :D LOL
batwad
Unread post by batwad »
On my 306 HDi you can feel the turbo from about 1300rpm, up to 3000rpm. It really gets going at 2000rpm, that seems to be the sweet spot.
