I had assumed from reading various forums, that the pollen filter woudl be in the passenger footwell, under the glove box, behind the various switches.
However, when I got in there to look (having bought a replacement filter) I can't find anythign that matches the shap of the filter!
So 2 questions.
1: Just exactly where is the pollen filter? I have a 96 2.1 TD 605.
2: What shape should the filter be? I have bought one which is long (ft and a bit) with a 'bump' sticking out in the middle. The only thing I found in the foot well under the dash board was a round cyclinderical type shape, which was COVeRED with wiring loom and fuses!
Adam.
605 pollen filter location
605 Only an SL but it is a DT with a shake rattle and role!
Mk 1 MR2 waiting to have the final useful bits removed... RIP.
1) this will help, i trust
http://www.boschautoparts.co.uk/pcCFil10.asp?c=2&d=1
click on peugeot, then scroll down to 605 and click on Installation instruction, it opens a pdf file.
2) cant really help here, maybe take the old one out
currently no citroens
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
Genious! What a result! thank you very much, I would have spent weeks looking for it!
Totally wrong place I was looking.. and it looks like I have the right one as well!
thanks again!
thanks again!
correct i am a genious your most welcomeAdstar wrote:Genious! What a result! thank you very much, I would have spent weeks looking for it!
thanks again!
The Bosch book says 10 minutes, but I had to spend an extra 5 minutes digging out all the leaves n other creepy crawly crap that had amassed over time.
My air con now actually blows air at me.. and it doesn't stink!
Thew only job left now is the lights for the climate control dials!
