I had assumed from reading various forums, that the pollen filter woudl be in the passenger footwell, under the glove box, behind the various switches.
However, when I got in there to look (having bought a replacement filter) I can't find anythign that matches the shap of the filter!
So 2 questions.
1: Just exactly where is the pollen filter? I have a 96 2.1 TD 605.
2: What shape should the filter be? I have bought one which is long (ft and a bit) with a 'bump' sticking out in the middle. The only thing I found in the foot well under the dash board was a round cyclinderical type shape, which was COVeRED with wiring loom and fuses!
Adam.
605 pollen filter location
Adstar
605 Only an SL but it is a DT with a shake rattle and role!
Mk 1 MR2 waiting to have the final useful bits removed... RIP.
Adstar
Just incase anyone else needs to know, and hasn;t seen the similar post in the peuget section:
The pollen filter on these cars is under the plastic cover at the top of the engine bay and bottom of the windscreen.
