This is for the 2-port pumps found on both Mk1&2 Xantia.
The pulley on non-V6 pumps must be removed with a special puller tool.
The O-rings and capscrews are applicable for all pumps.
Note the many pump variants
http://www.citroen-pr.net/catalogues/il ... 912150.gif
0290 03 391215 HP PUMP POMPE 6+2 + ANTI-AFFAISSEMENT
12/21/2005 2 HP PUMP 0290 03 3912 15
NOTA : ASSEMBLY WITH DISTRIBUTOR - PRESS PUMP 6+2 + NON-SINKING
01 - 4007 T3 - HIGH PRESS PUMP
- INJECTION XU10J2 AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING
- INJECTION XU10J4 AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING
01 - 4007 T5 - HIGH PRESS PUMP
- DIESEL XU AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 06444
- DIESEL XUD9 AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445 UNTIL RPO No. 07260
- DIESEL XUD9 AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING SINCE RPO No. 06445 UNTIL RPO No. 07260
- DIESEL TURBO XUD9SD AND PRESS PUMP 6+2 + NON-SINKING UNTIL RPO No. 07260
- TURBO DIESEL XUD9TE AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 06445 UNTIL RPO No. 07260
01 - 4007 T2 - HIGH PRESS PUMP
- PRESS PUMP 6+2 + NON-SINKING AND POWER STEERING AND WITHOUT AIR CONDITIONING UNTIL RPO No. 06444
- INJECTION XU7JB AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING
- INJECTION XU7JP AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
- INJECTION XU7JP4 AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
- INJECTION XU5JP AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
- INJECTION XU10J2 AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
- INJECTION XU10J4 AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
01 - 4007 T4 - HIGH PRESS PUMP
- INJECTION XU5JP AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING
- INJECTION XU7JP AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING
- INJECTION XU7JP4 AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING SINCE RPO No. 06445
- INJECTION XU7JB AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING
01 - 4007 T9 - HIGH PRESS PUMP
- TURBO INJECTION XU10J2TE
- INJECTION XU10J4R
01 - 4007 T7 - HIGH PRESS PUMP
- DIESEL XUD9 AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING SINCE RPO No. 07661
- DIESEL TURBO XUD9SD AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 07261
- TURBO DIESEL XUD9TE AND PRESS PUMP 6+2 + NON-SINKING SINCE RPO No. 07261
- TURBO DIESEL XUD11BTE AND PRESS PUMP 6+2 + NON-SINKING AND WITHOUT AIR CONDITIONING
- TURBO DIESEL XUD11BTE AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING SINCE RPO No. 07445
01 - 4007 T8 - HIGH PRESS PUMP
- TURBO DIESEL XUD11BTE AND PRESS PUMP 6+2 + NON-SINKING AND AIR CONDITIONING UNTIL RPO No. 07444
02 - 4007 Q9 - HIGH PRESS PUMP
- INJECTION ES9J4
03 - 4026 86 - 01 - HYD OIL O-RING
04 - 4026 87 - 03 - HYD OIL O-RING
05 - 4026 88 - 03 - HYD OIL O-RING
07 - 4009 C9 - 01 - STR PUMP PULLEY
- INJECTION ES9J4
08 - 4009 E0 - 01 - PULLEY HUB
- INJECTION ES9J4
70 - 6923 C2 - 03 - CAPSCREW
71 - 6922 73 - 04 - SELF-TAP SCREWS
- INJECTION ES9J4
