Rear suspension
stuwestwales
Rear suspension
My xantia hdi rear suspension to me is not coming up high enough. The front comes up smoothly and settles to the correct height and then the rear rises but to me only slightly then settles. The top of the tyre seems to be level with the bottom off the wing. Is this correct?. If i adjust the rear height adjuster slightly will the front automaticly adjust accordingly. I have been spraying both front and rear linkages with WD40 over the last few day but no change as yet. The plastic clip seems to be ok and the suspension rises from low to high and high to low with no problems. Any advise would be great..
mezuk04
> At what height setting is the car set at when the tyre and wing are level(ish?) ?????The top of the tyre seems to be level with the bottom off the wing. Is this correct?
If the height setting is at normal and the the bottom of the wing panel is level with the top of the tyre then the car is riding a fraction to high, but for that amount its hardly worth correcting.
If the car is at the highest setting and the tyre and wing are level then you have a huge amount of height still to achieve.
Can you just clarify those couple of things?
Volkswagen Golf 59' 1.6TD S
stuwestwales
- x 1238
mezuk04
If its at that sort of height you mention at 'normal setting' then thats about right, on mine or rather my BIL's it is slightly lower but as long as its in that general area then i shouldnt worry to much.....looks like you need to inform that 'other' driver he's riding HIGH
Ooww and mine was riding high by about 2 inches when I first bought the car, it never seemed to drive comfortably, informed the peeps on here and was advised to drop the car after posting some pics of the position of the car and tyre
after the height was adjusted all was well.
bxbodger
