Is it possible to overhaul Bosch diesel injectors ? Are there kits available for such a work from motorfactors ?
Car is question is a Xantia 1994 TDSX (Bosch pump) with 135K on clock.
thanks
injector overhaul ?
bxbodger
pwatson
roy,
If I may be so bold as to ask (being technically pretty incompetent!!) why do you think they need an overhaul.? Having had a few XUD diesels, 2 of which did far more miles than yours without having the injectors overhauled, I wonder whether a dose of Millers and an "Italian tune up" might be the answer?
Phil
jeremy
They can be overhauled. Instructions for Lucas ones can be found here - and Bosch will be much the same.
http://users.skynet.be/sn/manuals.htm
There are many independant Diesel specialists who will overhaul them for you but it may be worth checking new prices first.
jeremy
jeremy
jeremy
roypch
