deian wrote:simon.... and all...
i did some priming today.... lowered the car, open the bleed valve, looked into the lhm resevoir.... and i've seen some bubbles before but this was like a can of beer being opened after been shaken, it was bubbles like there was no tomorrow, didn't stop for a long time, brakes are still delayed, not much difference, but so much air?? i tend to think one of the rear spheres has leaked big time? any pointers?
thanks
Hmmmmm.......
Did you notice the bubbling in the tank after just lowering the suspension, or was it not until you opened the regulator bleed screw that you saw it ?
To actually see frothing in the surface of the oil in the tank requires a LOT of emulsified air bubbles, due to the way the returning oil arrives inside one of the filters and can only gradually difuse out into the main tank.
The smaller amount of air bubbles/leak that I'm chasing on my car is not enough to cause visible frothing in the tank surface...
I agree with Anders too - stop ducking and dodging and bleed those rear brakes
If nothing else it will give us some information as to what might be going on...and anyway, lowering the suspension and/or opening the regulator bleed screw will do nothing to bleed the brake lines...(since they're dead ends)
If you've got frothing going on in the tank then trying the clear section of return hose as I showed in a recent picture may help you find out where it is coming from. (By observing WHEN bubbles go by as you do various things such as lowering the suspension etc)
Edit: Waaaaaait a minute.... when you say you've "done some priming" do you mean you disconnected the hose from the resoviour to the pump ? If the answer to this is yes then you will get frothing in the tank for a few minutes after that because you inevitably get a bunch of air in when disconnecting the hose.
The only time you would ever do this is if the pump wont pump at all because it's lost its prime. Definately not something you would do when trying to bleed the system...(maybe I've misunderstood you)
Regards,
Simon
