hi, my air con's not working, its a 2001 406 2.0 hdi 90. the fans come on but the compressor clutch wont. i checked the pressure with a guage and its just on the green/blue mark. i went to halfrauds to get a refill can, then when i got in the car to come home to top up the air con was working, so i topped it up and it stayed working, turned car off went back to it several hours later and it is not working again.... f-ing thing.
ang ideas??
thanks
toby
p.s. it was only working intermitently b4 that.
406 no air con......
Clogzz
- x 40
meonk
bit of an update, still not working, im getting 12v at the compressor plug with it disconnected but as soon as i reconnect it i get no volts at all. disconnect it again and there is 12v again. stripped back the poz wire and put a feed from the battery and the compressor works. any more ideas please
thanks
toby
thanks
toby
Clogzz
- x 40
