Xantia Brake Torx sizes
awg2
Unread post by awg2 »
Does anyone know the size of the two Torx attaching the front brake caliper to the hub? It is bigger than my largest (50) but I don't really want to have to buy a range of biggies to find the correct one for just one job.
[I never needed them before as my Morris Minor of blessed memory used only a random range of slots, crossheads and conventional bolts with LHS carefully unmatched to RHS.]
C5 2l 2001 130K - daily use X-country (must change job)
Xantia 1.9TD Estate VSX 1995 111k - daily use X-county
3xBX 1xGS 1x16 TS - oh that was a Renault
Kowalski
Unread post by Kowalski »
I think its T55 but don't quote me on that.
awg2
Thanks for that.
I have now found (Note to self "REMEMBER TO SEARCH") a 2002 thread with confirmation of T55 as the size. (T30 for the disc bolts).
x 1408
Unread post by xantia_v6 »
If you are hving trouble finding a T55 bit at your local shop, they often have packaged as a tool for Ford cylinder head bolts.
DerekH
Unread post by DerekH »
A useful tip:- ram some blutak into the orifice and carefully remove it. You can then take this along to your tool supplier to compare sizes.
Derek
deian
Unread post by deian »
wow, cool tip, genius DerekH!
Kowalski
DerekH wrote:A useful tip:- ram some blutak into the orifice and carefully remove it. You can then take this along to your tool supplier to compare sizes.
Derek
Does this also work when you need to get keys cut or do you need a bar of soap for that?
deian
who's house are u trying to rob then kowalski? 8) i would stick to blutak for that job, don't think the keycutter will think you are sane turning up with a bar of soap and a shape squashed into it, but blutak i think it's seems more clever.
it's cool that you can take any key and blutak the shape, then you can create your own set, something a piece of mild steel and a dremel will achieve me thinks... remember 'through they keyhole' with david frost? :wink:
