Hi to all,
How can one tell if the break valve has packed up?
Sometimes when I break hard, the front of the car raises immediatley after the car reaches a full stop. It rises in one unique movement, like a bump. It also happens that when stopping at a downhill (eg at a crossroad - yes I do respect the STOP signs!!), the rear also does some funny up and down going.
Any ideias? are these symptoms of leakage?
Rostami.
Xantia Activa: break valve?
Rostami
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
AndersDK
No -
Thats more like air in the rear brake lines/calipers.
"air" should be interpreted as escaped N-gas from a sphere.
You wont ever notice a failing brake valve in a hydraulic Citroen - unless it is so bad it provides you with a green foot bath or similar serious symptoms
PS : before bleeding the brakes do the Citaerobics.
(some call it Limbo-rock - if that means anything to you
Anders (DK) - '90 BX16Image
Rostami
