Cylinder Head Cures
p20
Cylinder Head Cures
Unread post by p20 »
Hi, my dads got a problem with his cylinder head. The car starts fine, but after about 2mins, the exhaust starts steaming like a kettle. Clean white steam, no trace of oil. A mechanic friend has said the head has probably cracked. :cry:
He only needs the car to last for another 6-8wks until he can get a new one. He's heard of a fluid which can seal small cracks in cylinder heads. Anyone had any experience of these? The car isn't worth doing anything with, so hence looking at temporary fixes.
Any thoughts, i'd be grateful. Cheers
307SW HDi 110
fastandfurryous
x 4
Depends what the car is, but it could just be a good-ole' head gasket.
In which case, shove some barrs leaks in it, and see what happens.
But don't use radweld. That will only make the problem worse!
This is not a signature.
p20
Cheers F&F. Its a 1.6 cavalier. Will try some bars leaks
307SW HDi 110
goldfinche
Leak sealing.
Unread post by goldfinche »
Hello I have used something called K - seal and it sealed a badly leaking head gasket on a BX 16V, it was meant to be a temperary thing untill the gasket could be replaced. That was a year ago and no problems. Be worth a try.
Cheers.
Geoff.
