ECU schematics/pinouts for 2.1TD (lucas epic)
deian
Unread post by deian »
Hi Gang,
Has anyone got any wiring diagrams, pin outs, or schematic maps for the Lucas EPIC based ECU and it's ancillaries? Also for body computer (central locking etc, alarm). Just printed out schematics for the hydractive 2 now.
Any help or pointers would be so cool. Maybe someone has access to technical info via a book not easily available. If so let me know what you can do. Thanks
Rostami
Unread post by Rostami »
Sorry if it is too obvious, but doesnt Haynes BOL have enough info on that?
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
deian
Well it doesn't have pin outs and schematics does it? Unless I've missed that one?
Rostami
ECU Schematics are in general VERY hard to find, although at a system level they are all pretty much the same thing. Unfortunately my Haynes does not have the 2.1TD ecu pinout. Sorry!
deian
No problem, I have the Haynes BOL too, they are quite limited. Thought someone on here may have access to more of the technical info flying around. Thanks anyway.
noz
Unread post by noz »
Hi deian,
Can you tell me the RP number of your car? Can you confirm that the engine code is XUD11BTE? If so I have the factory manual for the injection system, the fault code list and the pin outs. It is the same engine as fitted to the XM. Please e-mail me off list.
Cheers
noz 8)
Fight the good fight against the governments stealth tax scheme of speed cameras
'88 CX 22TRS '87 CX 25GTI '95 XM 2.5TD VSX '96 XM 2.5TD VSX and '98 XM 2.5TD Exclusive
http://club-xm.com/forum/index.php" onclick="window.open(this.href);return false;? The Ride of Your Life !
deian
I've contacted you by pm, thanks mate!
