CitroenNuts wrote:It been a while since I last had a xantia as I have had the C5 for just about a year but cant get over how different the suspension is
Its so soft and bouncy I’m concerned that it might have the wrong spheres or am I being paranoid?
The back end is like sailing a boat not driving a car. All the xantia’s I’ve had in the past have been the VSX or Exclusive models with the awkward suspension so this is my 1st normal one is there any solid way to test or at least reassure myself that its normal
If you think its soft and bouncy like a sailing boat then its probably NOT ok
The wrong spheres can easily give this result. One common mistake (which even Citroen agents seem to be making sometimes) is putting estate rear spheres onto a hatchback, which will give a ride at the back that is TOO soft with not enough damping like you describe. (The rear end feels like it has a mind of its own at speed....)
Let us know if your car is a hatchback or estate, and see if you can find the numbers printed on one of the rear spheres - there should be a stamped 2 digit number by the filler plug (30 or 40 for a Xantia) and also the part number which is a long number starting with 9 for genuine spheres, or a short number starting with an N for GSF spheres. From those numbers someone can look them up in a sphere table.
Sorry about this just want to be safe
1999 Xantia 2.0Hdi SX
Forgot to say did notice that front wheels are 195/60/15 but rear ones are 205/65/15 would this make much odds is this safe?
Should be ok, although putting bigger tyres on the back may bias the car slightly more towards understeer on the limit.
If the bigger tyres are in good condition I would be inclined to swap them to the front, although if you don't push the car near its limits you probably won't notice the difference.
I had 205/60/15 on the front and 185/65/15 on the rear of mine for quite a while without any problems. It's important that the tyres on each side of the same axle are the same size though of course.
Regards,
Simon
