AX running nightmare!
triumphtoledo
Hey guys! Any ideas on the following fault which is driving me nuts?
Car is a 1.0 N reg AX, with Bosch Monopoint fuel injection. 65,000 on the clock. The following problem has appeared within the last 30 miles.
When cold, the car starts and runs fine. As it warms up to normal temp, the car hesitates, loses power and "bunny hops" at any throttle opening; worse when driving round town. When a revving engine is returned to idle, the engine idles at around 1200 rpm before dropping to around 800, but sometimes "hunts"; and sometimes drops so low the engine almost stalls. If the engine is revved and held at 2,000 rpm in neutral, the engine speed drops to idle even though the throttle is applied.
If the AX is taken on a fast run to say, 60 - 70 mph with a few racing starts, the above symptoms disappear; however if the engine is switched off for more than 5 minutes, the problem reappears.
The throttle body has been taken off and cleaned with carb cleaner. The idle speed motor has been dismantled and is clean and in good condition, and the 3 electrical connections have been checked and cleaned...no difference.
I suspect the lambda sensor next...any ideas guys??
Thanks!
Rob
Thanks!
Rob
mezuk04
My old Zx 1.4i use to do the sort of thing you describe added with stalling pretty much all the time...In the end I believe it was down to air in the fuel lines however I cant be sure (hated that car for that problem).
It would stall when braking, accelerating, when the clutch was pushed down....just anytime.
Volkswagen Golf 59' 1.6TD S
AndersDK
The Lambda sensor would not cause that kind of erratic engine running. That would be more like a steady rich running symptom.
IMHO when you have this very erratic rpm (stalling tendency) despite trying to correct with the acc pedal - then its the throttle potientiometer teasing you. Because of a worn out (a hole in the) carbon track.
If that was true the engine would also show a tendency to "ghost" reving at its own mind. I.e. may suddenly run up to 3-4000rpm for a while - and then shortly after it may stall.
If the engine does NOT do that rpm ghosting, I'd say with the symptom of yours it would be the map sensor playing up.
Anders (DK) - '90 BX16Image
triumphtoledo
mezuk04
- x 94
triumphtoledo
mezuk04
I'm no expert as many would agree
But I seriously doubt a temperature sensor would cause this kind of problems your having, I would investigate Anders post (location still unknown?) and I also agree with Citronuts post, an air leak would cause the problems your having also.
triumphtoledo
mezuk04
triumphtoledo
re
I have found a pipe that comes from the throttle body to the nearside rear inner wing. There is a white cylindrical unit, that almost looks like a one way valve, with a connector going to it. From there, the pipe disappears into the gap between the inner and outer wing. Is this the MAP sensor I wonder?
Sl4yer
We've had this argument many times before on this forum!
The Monopoint ZX has no MAP sensor. Some claim to have found one, but I'm sure it doesn't. The BoL agrees.
I would expect a Monopoint AX to be the same. I think what you have found is the vapour recirculating thingy.
I would recommend that you take the car to a Bosch dealer, and get them to take a look with the car plugged into their computer. It may be that the pot is giving a dodgy signal (even though it looks OK).
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
triumphtoledo
UPDATE!!
Removed throttle body, replaced it with a known good throttle body...and it still does the same! Drat!
If you hold the throttle to 2500RPM when stationary, the engine stays there for about 5 secs, then drops down to tickover, when the throttle is released, the revs increase to 1,500 then back down to tickover then up again to 1500 then tickover and there it stays.
Any more suggestions before I srap the thing??!!
Thanks again!
Thanks again!
Ian Fearn
I've had no end of running problems with an AX 1.1i. I replaced the ECU with one off a scrap car.
No problems since, might be worth a try as theres tons in my local scrappers.
1983 2CV6 Charleston 110k (Re-build in op!)
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
1998 Xantia V6 Exclusive
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
