Is there a difference between the estate and saloon front doors and also between the mk1 and mk2
Awaiting the replies with anticipation
Kenny
C3 1.4 petrol (SWMBO)
I've read that the Estate was built by someone different than the saloon. There are numerous threads about the estate doors loosing their weld.
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
Don't quote me or anything BUT everything different happens aft of
the B pillar! I've got a 98 S2 estate in a barn that I can check out against a 95 S1 saloon if that's what you're trying to compare the front doors with...
Yeah , If you could because I've found a Mk2 door right colour etc on a saloon.
Kenny
I'm more than happy to check my cars for you but I wont be be able to check them out until the weekend. That said, I've looked at Citroen's parts database and S1 & S2 Xantia doors check out to be EXACTLY THE SAME for the front and the rear doors irrespective of their age. There's certainly no mention of Xantia Estate FRONT doors!!
Hope this permits you to get hold of the doors you need for your Estate!
Actually, the only likely problem that I can forsee is the S2 car has colour coloured waist line door cappings but the earlier ones will have the textured black cappings. Have you fully cross checked the colour codes off both bulkheads...
I've just checked the Citroen pr-net site and put my chassis No in and the front doors appear to be the same for all Estates and saloons MK 1 and 2.
Thanks for everyones help.
Regards
Kenny
Hi Kenny, Fitted a replacement drivers door on my estate about 1 month ago, that door came off a hatchback and was a perfect fit, the only thing i did replace new was the hinge pins which were approx £1.30 each...Regards Colin
CURRENT CARS:-
2018 CITROEN C4 PICASSO BLUE HDI FEEL 120BHP (WIFES CAR)
2020 CITROEN C3 AIRCROSS 1.2 FLAIR PURETECH 130BHP AUTO (MY CAR)
Done the o/s/f door 2 years ago and become quite adapt at removing same had n/s/f door off last week and hinge pins are fine.
Thanks for the help to all
Kenny
Hi xantia estates were built by HEULIEZ. as were BX and I think XM .The new VAUXHALL TIGRA is also built by HEULIEZ , check the badges on the front wings. Have a look at their web site. Regards John.
THanks John for the reply .
Will look at the web site
Cheers
Kenny
