My TD was not as powerfull as my last and I put it down to the fact that this one is heavier (estate). Today I got a feel for the power it should have and all the way to and from work I tested it. The measure I used was the speed I got in 2nd before the engine sounded like it was going to pop... I was getting it up to 30 or just over then having to change. I would then have it to 40 quite comfortably and it felt much more powerful in every gear.
Everytime I got the extra power I couldn't tell what was different with my driving style etc it just seems erratic!!!
I have recently (last week) changed oil, air and fuel filters. I noticed that the really painfull glow plug hasn't been changed but the others have and I found a broken pipe coming from the fuel pump to one of those large air pipes (I cut it back to good pipe and jubilee clipped it back in place).
Power then more power then less again......
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
My problem is that the car feels more powerful only some of the time. Where as before it felt under powered all the time noe it comes and goes. Any ideas??
Not sure how you'd check pipes for leaks.
Personally what I would do it is take them all off, give them a thorough visual inspection... i.e bend them at the bends looking for cracks or brittleness, holes, or anything that seems dodgy, if you are happy with it then put it back on and make sure you are happy with how tight it is, only you can judge what a good seal is and what is obviously a candidate for leakage.
Of course, when i say take all pipes off for inspection, i suggest taking one off, and putting it back on before taking the others. Last thing you need is a load of pipes not knowing where they go.
Basically just use your instincts, you will find it in the end. Dig the Haynes manual out and see what pipes are involved with the engine, turbo, and exhaust recirculation systems. I'd clean them too, with some cleaner, that protects pipes, just normal automotive plastic cleaner will do. Something else geeky i'd do is label the pipes, to say if they are good and checked and cleaned, also what the pipes does, and direction of airflow etc etc, process of elimination yea, and future reference.
Sounds like fun yea .
