xsara hand brake adjustment
rabenson
Unread post by rabenson »
Does anyone know if the handbrake on the xsara is self adjusting? if so, is there any procedure to assist it - my handbrake is becoming decidedly weak..... 8-[
Cheers,
Ron
ps HDI with disks all round
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
x 1456
It should be - they use similar screw out calipers to the front of hydraulic cits. Just press the brake pedal down hard a few times and it should adjust up. If not, you may have a cable on the way out, or the pads are worn out - more investigation will be required.
jeremy
Unread post by jeremy »
Certainly my BX handbrake (sounds like the same thing) adjusts best if I press hard on the brake and pull the lever up a few times while maintaining pressure on the brake.
jeremy
rabenson
Thanks, guys - I'll give it a go!
Ron
