The air con has stopped working and also the heater n my 206 hdi dturbo?
No fuses have blown and have swapped relays around but nothing?
When you turn the buttons the lights come on saying they are on but nothing.
Any ideas or is they a known fault with these.
The car is a 2000 W reg
Air con/Heater not working on 206
visagti
Visa Gti 105ch - white - under restoration - NO RUST never painted
Visa Gti 105ch - red
Visa Gti 115ch - white - requires tlc
Corsa CDTi SXI+
Impreza WRX Wagon
Corsa CDTi SXI+
Impreza WRX Wagon
pugxpert
your a/c will not work as thermostatic ecu need to see voltage to fan before compressor gets supply to cut in,needs to be on at least speed 1 for it to work.you shoul have supply at heater control panel on pin 5a which is ignition supply through fuse40,if ok check supply out of heater control panel on pins 2b,3b,4b and 5b this will change to each one depending on which speed you have setting on,my guess is resistor pack is open circuit ,take heater fan out and gain access to it through there.
EP6T petrol turbo nice engine in the 207 GT and the new mini....
