checking condition of fuel filter
_kid_
Unread post by _kid_ »
Ive just change my fuel filter on the xantia, on the petrol model it sits next to the fuel tank on the offside.
I was surprised to see the outside of the filter nice and clean, so obviously i would like to know the condition of it, (it has not been changed in the 2 years ive owned the car)
Is there way i can tell?
currently no citroens :-(
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
citroenzx
Unread post by citroenzx »
if it hasn't been changed in 2 years then for the sake of £10 or so change it
  ...:::CITROENZX:::...
_kid_
citroenzx wrote:if it hasn't been changed in 2 years then for the sake of £10 or so change it
i have changed it :D but i am simply curious if there is a way it can be checked, eg like a air filter which is either clean or black.
AndersDK
Unread post by AndersDK »
Blow thru it and judge. There will not be much flow during use - i.e. nothing like water from a tap. So it has to be well clogged not to function.
Anders (DK) - '90 BX16Image
jeremy
Unread post by jeremy »
get it nice and wet with fuel and blow fuel through it in the wrong direction and see what comes out!
Easier just to replace it!
jeremy
BonceChops
Unread post by BonceChops »
Cut it in half and have a look whats inside it.
Now Citrtoenless
Clogzz
x 40
Unread post by Clogzz »
If the filter is very clogged, the engine will cut out when going at speed uphill.
That’s when fuel flow is highest, and restricted flow will show up then.
x 8181
Diesel fuel filters look quite discoloured on the lower half when well used. The one out of my Xantia, which had been there an unknown time was half black and half brown.
oscarloco
Unread post by oscarloco »
Just tilt it so the fuel flows from the inlet side. I just replaced mine and the gasoline that came out was a dark red :oops:
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
