buying spheres... Hydractive or not???
eskimoigloo
Unread post by eskimoigloo »
Hi, am getting fed up with my rough ride so am looking at replacing all of my spheres... only problem is I don't know which ones to buy from GSF? It's not ticking very often so wasn't going to bother with accumulator,
1) do i need a centre front?
2) is my car hydractive or non? (2001 Hdi 110 - only the height adjustment lever, no extra buttons), for the 2 fronts and 2 rears
3) do i need a centre rear?
4) guessing i need anti-sink as it has started to drop at rear over night?
I've read all of the methods for changing, so any advice on what i need would be greatly appreciated...
Cheers, Chris :roll:
2001 Xantia HDI 110, 50,000 miles
Near Beverley, E.Yorks.
AndersDK
Unread post by AndersDK »
Hi Chris -
You dont need to mess around underneath your car identifying Hydractive system or not :
The diameter of the rigid piping for Hydractive suspension cylinders is a hefty 10mm - the standard suspension system piping diameter is only 3.5mm.
Look in the engine bay at the spheres 8)
You have read about the softness test jerking the suspension - and the Citaerobics - and done it ?
Anders (DK) - '90 BX16Image
eskimoigloo
Not quite understanding what you mean about the softness test??? you mean pressing down on front and rear of car with engine running? It doesn't move very far in my opinion! All the solid pipes are small diameter.
Chris.
bernie
Unread post by bernie »
Chris.
That makes it NON hydractive
3 Fiat 124 Sport 1969x2, 1968
2 Fiat 124 Spider 1976, 1971
1 Fiat 20VT Coupe Plus
BUT maybe moving to France
Gregg1100
x 5
Unread post by Gregg1100 »
Hi Chris,
Below is link for GSF Sphere Table.
http://www.gsfcarparts.com/downloads/sphere_table.pdf
Hope this is handy for you.
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
eskimoigloo
to conclude...
So if it's non hydractive do i just need 2 fronts, 2 rears, anti sink, and maybe accumulator? :?
Cheers, Chris.
AndersDK
Yes Chris :wink:
BonceChops
Re: to conclude...
Unread post by BonceChops »
eskimoigloo wrote:So if it's non hydractive do i just need 2 fronts, 2 rears, anti sink, and maybe accumulator? :?
Cheers, Chris.
Before you change that anti-sink sphere read up on it. You have to unscrew the pipe that goes into the back of it, if you don't you will snap the pipe off as you unscrew the sphere.
Now Citrtoenless
eskimoigloo
Thanks for the help... best get on and buy them then!
