Search
awg2
Search
Unread post by awg2 »
I've just done a search on 'C5' and it returned nil results.
I previously searched on 'C5 AND lock' which returned the same result as for 'lock'.
I DON'T have this problem with 'Xantia AND lock' or 'xantia'.
Anyone else tried this? I really want to look at C5 search returns.
Maybe short alphanumerics (C5?) get ignored. This could be a problem with the current model range!
C5 2l 2001 130K - daily use X-country (must change job)
Xantia 1.9TD Estate VSX 1995 111k - daily use X-county
3xBX 1xGS 1x16 TS - oh that was a Renault
mezuk04
Unread post by mezuk04 »
It makes a big difference to the amount of posts i get when i do a search.
When you type in the search field select the 2nd dot option underneath and also obviously to search in the Citroen forum at the lower left of the page.
Volkswagen Golf 59' 1.6TD S :(
f00lzz
Unread post by f00lzz »
Perhaps nothing has been posted about C5 locks :-k
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
awg2
I get nothing when I search for C5 and I KNOW there have been posts with C5 in either the title or the text. :?
f00lzz
Oh yeah! I see what you mean.... never an Admin around when you need one :lol:
The same thing happens if you only type in 1.9 or 2.1 but if you add td or hdi it works
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
f00lzz
Ahh looks like you have to put in more than 2 digits e.g XM or CX won't work but 2cv will or Ami :)
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
AndersDK
Unread post by AndersDK »
f00lzz wrote:Ahh looks like you have to put in more than 2 digits e.g XM or CX won't work but 2cv will or Ami :)
Why would you need an admin ...
Anders (DK) - '90 BX16Image
f00lzz
Help & advice maybe??
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
awg2
It does seem a little unfortunate that we cannot search for, say
CX, C5, BX, XM, C4, GS, ID, DS, C6, C8, C2, C3, AX, SM
on a Citroen forum :cry: :cry: :cry: :cry: :cry:
Fortunately I drive a Xantia :lol: :lol:
f00lzz
:lol:
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Kowalski
Unread post by Kowalski »
awg2 wrote:It does seem a little unfortunate that we cannot search for, say
So, we'll have to use longer spellings.
From now on when you're on your peasea on the forum, its SeeEcks, SeaFive, BeeEcks, EcksEmm, SeaFour, GeeEss, EyeDee, DeeEss, SeaSix, SeeEight, SeaToo, SeeThree, AyEcks, EssEmm.
mezuk04
A lot of thought and time went into that last post.....thats dedication for you :wink:
Sid Boggle
Unread post by Sid Boggle »
phpBB.com support wrote:phpBB 2 uses a Fulltext search system, this has both advantages and disadvantages. The advantage is that on large or busy forums it has far less impact on server load than standard search methods as used by many alternative forums (including phpBB 1.x). The disadvantage is that to reduce the size of the database (every post is examined and unique words stored in a table) we have to limit the size and type of words we store. By default words must contain at least three characters but no more than 25, they must be either alpha or combinations of alpha and numerals (numbers alone are not stored). In addition all non-alphanumeric characters are removed, eg. _, +, -, etc. This is standard practice for fulltext search solutions.
f00lzz
Now thats what I call 'support' Ok so we sussed it ourselves eventually, but nice to know we have the necessary expertise if we need it :)
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
