Evening all,
I have just discovered my 405 TD had a leaky radiator. Obviously I'm now after a replacement, but what I want to know is...
What oter model rads will fit, i.e. Pug petrol model rads, Citroen rads?
Thank, Robin
TD Radiator Question
fastandfurryous
- x 4
caveman_si
Have a look in yellow pages fo radiatior repairs if you cant find a replacement one. I took mine to a local place 2 yrs ago when i thought it was leaking for a repair as they came recomended. They washed it out and pressure tested it and it was fine 15 mins of work and the guys didnt even charge me!!!
AS it turned out it was leaking from a pipe that connected to the rad but i only found that out once i had refited it doh!!!!!!!
(and it is possible to remove the rad on a 405td with a/c with out removing anything except the air pipes and your knuckels)
406 lx 1.9td estate
fastandfurryous
- x 4
