Can anyone tell me where the top up plug is on a AX 1.1 gearbox,as mine needs a drink after the halfshaft came adrift today,while changing a strut.
I have an idea,but want confirmation,and also need to know what size the plug head may be,if it's the one I'm thinking it is.
Cheers peeps.
Ken.
AX gearbox oil top up.Help needed.
Quinny
99 406 HDi. (Mine)
02 Xsara HDi. (The gaffers.)
fred1
If it is the same as the 1.0l (and I believe it is) the plug is on the side of the gear box towards the the front (passenger side), between and slghtly above two hex head bolts. It requires a "square" ended tool (7mm-5/16inch) to remove it, which happens to be the same size as the connecting rod on most internal household door handles. If you are stuck one of these (temporarilt removesd) and a spanner will normally serve. I find a good pump oil can is the bet wat to put in the oil as there is no room to upend the oil bottle and use the supplied filler tube.
Pheonix
AndersDK
You dont change gearbox oils - its supposed to last "forever". In practical terms it means you change it after larger service works like a clutch change when you have to drain it out anyway.Pheonix wrote:Quick question roughly on the subject....
How important is it that Gearbox oil is changed? I'm talking a 1.0 106 here.
Sorry to but in
The reason is that the gearoil is "only" exposed to mechanical load - there is no extreme temperatures - and change of temperatures. Neither is it exposed to a combustion process which leaves all sorts of crap in the oil.
Anders (DK) - '90 BX16Image
Kitch
