Hi Gang,
I know I read in another thread that the pressure on the rear sphere's for estates is higher than the saloon but what should it be?
I think I've bought the wrong spheres a little while ago.
Regards
Kenny W
Xantia Suspension Spheres
KennyW
- x 163
C3 1.4 petrol (SWMBO)
KennyW
- x 163
sphers
Hi Gang,
I've found what i was looking for Back spheres for estates 40 PSI.
Anybody out there confirm same.
Regards
Kenny W
Regards
Kenny W
AndersDK
Errr...
Yes I know Simon (mandrake) once wrote in a reply that these spheres should be 40bar initial charge pressure.
But thats certainly not the only spec to meet for correct function. You will notice that if you search for spheres with 40bar pressure - there are numerous types to choose amongst.
It must be the correct type no for '98on Xantia 1.9TD Estate (in your case) - and specified for either hydractive or not - whatever is fitted on your TD Estate.
Reason is that the damper ("shocker" function valve) is build into the sphere also. And you dont go buy Fiat Punto shockers for an S class Mercedes or vice-versa ...
Anders (DK) - '90 BX16Image
KennyW
- x 163
Andersk,
Thanks for that,
Mine is Non - Hydroactive.
Just a bit concerned re the ride since I changed mine about 6 mths ago.
I thought I maybe got the wrong rear sus'n spheres, as I did say it was for an estate etc.
Regards
Kenny
Thanks for that,
Regards
Kenny
Mandrake
- x 694
Tell us the pressure stamped by the filler, AND the long black printed part number starting with a 9 and we can tell you if you have the right spheres...
And yes as Anders points out, there is more than just the pressure involved, but if the pressure is wrong you don't need to check the other things to know they are the wrong spheres
The estate rear spheres have a higher pressure AND larger damper bypass hole. The reason for this is because of the larger diameter hydraulic ram used in the estate.
If you put the estate spheres on the sedan the ride at the rear will be very soft and floaty with a lack of damping and rediculous amounts of squat on acceleration.
I know this because Citroen mistakenly sold my Dad estate rear spheres for his Xantia, and we noticed just this. It was thanks to this forum that I was able to find out they were the wrong spheres and get them replaced. (We were both new to Xantia's then and didn't know any better or have any information, other than what is on the internet...)
Edit: whoops, just noticed you have an estate not a hatchback. Well in that case, hatchback spheres on an estate will make the ride at the back a lot harder/harsher than normal.
Regards,
Simon
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 1240
Mandrake
- x 694
Hi Peter,Peter.N. wrote:Unless you carry a lot of weight in your estate, having hatchback rear spheres (if thats what you've got), shouldn't make a great deal of difference.
Unfortunately thats not the case - the reason for the difference in sphere is not so much to allow greater loads to be carried, but rather to compensate for the increased diameter of hydraulic ram used in the estates.
Estates use 40mm rams, while hatchbacks are 35mm before 1995 and 37mm after 1995. The increased diameter ram allows heaver loads to be carried for the same oil pressure.
However, if you don't change the sphere (eg still using a sphere like the hatchback ones) you will effectively make both the springing and damping much stiffer.
Therefore estate spheres have higher gas pressure and wider damper valve holes to bring the ride quality back into line with the ride of a hatchback, except thanks to the larger ram the maximum load capacity is increased.
Regards,
Simon
Simon
1978 CX 2400
1978 CX 2400
KennyW
- x 163
Thanks Peter and Mandrake,
I will have a look tomorrow re pressure and number.
Tried to find receipts for buying same but will check as sugested.
This may tie in with my other posting.
I will update the sight tomorrow.
Regards
Kenny W
Regards
Kenny W
AndersDK
Simon -
You are so correct going by the book - that you forget about real life and whats driving around on the roads
I can assure you - that if you get your - correct type by parts list - rear spheres re-gassed to +10bar - you wont feel any difference from spheresa on par with the pressure 8)
If your theory was correct - then after some (years of) driving the spheres have lost some 10bar in pressure (from initial) - the drive would become very detoriated. Thats not the case - reported from real life by the many BX'es (+ 1 CX) I have owned over the years.
Point is : the sphere pressure is allowed to be highly tolerant and still the sphere works as it should on the car.
BTW : I believe that VERY few UK owners of hydraulic Citroens ever get their spheres re-gassed or even checked. Here in DK I've never heard of it. We simply replace the spheres when the ride gets too harsh.
Reason ? - the car is already very expensive to maintain these days
