citroenzx wrote:Same problem with my lights left on buzzer, does yours let out a small clicky relay type noise though? i've tried fiddling about with the board where the buzzer is attached to and tried removing it to test but have had no luck with that.
Strange thing is i have had it sound a couple of times.
How did you remove the sounder, from what i can see its a twist and pull, i can do the twist but it still wont come out through the hole.
So it's "normal" for the buzzer to stop working
I have the same problem with my car, with one difference. One day I heard the relay clicking fast and then, smoke came out the steering column, not much but enough to scare the s*** out of me. Also, the turn signals would stop working sometimes when the relay started clicking and the only way to "reset" them was to turn on the "hazard" lights.
Never find the culprit but the relay stopped clicking and the buzzer stopped sounding.
I do sometimes get the "buzz" when light are on.
