Where's my Rev counter ? ? ? ?
Jshodgson
Could someone please describe, in ameteur language, where to find the connection on the engine for the rev counter that "may need cleaning" in order to get it working?????
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
- x 94
there should be a sensor in the clutch housing for the rev counter pick up,if you find this then follow the wire back to the plug block,was it you in an earlyer post asking about your speedo beeing intermitent as this will be a diferant plug which is behind the gear box end of the engine,right down the back pluged into the transducer which is fitted into the diff where a speedo cable would normaly go
regards malcolm
regards malcolm
- x 1240
AndersDK
These magnetic coil pickup sensors are prone to disrupt for good. I lost the rev counter on my BX TRD as well and found the connector on the clutch bellhousing. I ended up cutting up the cable from the sensor had both leads stripped down just to see it was fresh shining copper - but still was totally disrupted (high ohm).
As the sensor is located at end of cylinder head - "just around the corner" (on the rear of cylinder head) over/in the bellhousing - it is practically impossible to get at. Unless you are there for other serious repair works anyway - like a HG job
Might not be as bad in a Xantia TD though.
Anders (DK) - '90 BX16Image
- x 1240
