Side lights at the front don't work
Jshodgson
Unread post by Jshodgson »
My front side lights don't work, the rears do but the light on the dash doesn't either. I have taken the very small 5W bulbs out to see if they are blown. I can't tell so I'll change them anyway.
Does the Xantia have a clever feature that tells you the bulbs have blown by stopping the dash light from working?
Could it be anything else? They seem to share a fuse with the rears so it can't be that.
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
AndersDK
Unread post by AndersDK »
I have yet to read about an owner classifying the Xantia lights system as "clever" :lol:
I was going to say check the fuses - but this cannot be the problem as you still got the tail lights on.
That leaves a dodgy earth connection as the problem - which I believe is one of the Xantia landmarks - sort of :wink:
Pre '98 Xantias are reputed for bad earth points under the battery (remove battery and any tray). All Xantias are reputed for a sensitive wiring loom with an earth distribution point hidden under the loom sheathing - located directly under the radiator.
Anders (DK) - '90 BX16Image
x 1240
Unread post by Peter.N. »
Before you start fault finding with your dash lights, make sure someone hasn't turned the dimmer switch down with their knee!
Jshodgson
Thanks Peter I've checked and the dimmer is up to full power. I've learnt that when buying a new Xantia turn this down to the minimum and the one night treat yourself and turn it up to see how may dash lights don't work !!!!!! :lol:
It's like Xantia dash light roulette ! ! ! ! [-o<
Jshodgson
Anders...how do I improve the earth near the battery and where do I begin to look for the dodgy loom under the radiator?
AndersDK
Errr...
Start a bit more logic : use a needle tipped testlamp and search for a +12V at the bulbs with missing light. Next move the test lamp clip to the +12V battery pole and search for an earth at your bulbs. Once you know what is missng and whats working - you know where to go ...
x 94
Unread post by citronut »
before going looking for faults just try replacing the side light bulbs and check the side lamp warning light,always keep it simple before getting all complicated
regards malcolm
Village
Unread post by Village »
I had a similar problem with my ZX. I changed the side light and dipped beam bulbs at the same time and the sided lights would only work one at a time. I gave the contact/holder thing a wipe with a cotton ear bud and they both worked fine after that.
I had initially tried swearing at them, but as I can't swear in french, it made no difference. (mumbles) bloody foreign cars.....
French car free zone....
Clogzz
x 40
Captain Haddock
Unread post by Clogzz »
Here are a few of captain Haddock's most effective French swear words:
