ABS light is on. Tests show it to be 'NSF' sensor. I'm presuming this is the front wheel on the passenger side?
Went to the local scrapyard and obtained a couple of sensors from an R reg Xantia. Got home only to find that the body of the sensor is longer than those fitted. Is there a work around?
ABS light on and sensors 2001 Xantia
Re: ABS light on and sensors 2001 Xantia
No,Garysz wrote:ABS light is on. Tests show it to be 'NSF' sensor. I'm presuming this is the front wheel on the passenger side?
There are two types of ABS sensor, before 1995 and 1995 onwards, and they are a different lenght. There may be additional variations in sensor after 1997 as my data doesn't go beyond that. Sorry. You'll have to go back hunting in the scrapyard for a closer year to your car!
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Looking at the PR-net drawings it appears that Kowalski may have a good point there
Spacers may be obtained from a cheapo assorted set of plumbing alu + cu rings. Usually available at some 3-5 quid from tool stores etc.
Note that the mounting screw must be longer accordingly.
Remember the heat shields protecting the sensors from the very hot brakes discs
These are available cheaply from Citroen.
I'm a bit astonished you were able to save these sensors from breakers cars ? Usually they crumble if you try remove them - or are just as bad as the ones you've got.
Before fitting - check with an ohm meter. They should be some 1000 ohms. Dont go be any insane detailed ohmic data on the sensor. The way you are checking it with a home hobby meter can not be super precise.
Anders (DK) - '90 BX16Image
Yes there MUST be a clearance (usually just 1-2mm ish, check Haynes manual for exact measurement) otherwise the sensor will be destroyed. The sensors work by way of magnetic fields.Garysz wrote:I don't have a working ohm meter so I will try and fit with the packers.
Should the sensor end with the magnets touch the hub or be slightly above it?
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
If you buy a brand new sensor ( cheap enough now ) it should come with a sticker on the end.Richard Gallagher wrote:Yes there MUST be a clearance (usually just 1-2mm ish, check Haynes manual for exact measurement) otherwise the sensor will be destroyed. The sensors work by way of magnetic fields.Garysz wrote:I don't have a working ohm meter so I will try and fit with the packers.
That sticker is used to set the airgap
Get the airgap wrong & the ABS light will stay on & report a fault.
