I have both the side and main airbag lights on. I have read the posts and have tried unppluging, cleaning and then reassembling but to no avail.
Not keen on cutting the wires and soldering them all so can anyopne help me in identifying which coloured plugs / wires are the key ones? There appears to be a large block which goes no where and at least three other connectors orange, brown and white?
Air bag electrics under seat Xantia Hdi
easterroad
rabenson
rossnunn
Garysz
PowerLee
Driver & passenger airbag & the seat belt pretensioners work from one ECU.
The side airbags are controlled by another ECU.
2 different systems hence the different warning lights.
Some cars also have another warning light for the passeneger airbag to show when its switched off with the disarm switch.
A flashing airbag light could mean the rotary switch behind the steering wheel is faulty, It really needs the fault codes reading to be 100% sure.
If the light was stuck on all the time then I would say seatbelt pretensioners.
What ever you do DONT probe with a multimeter ANY of the SRS wires when they are conected to either an ECU or a pyrotechnic device, You WILL FIRE the SRS system if you do!
Unplug BOTH ends before checking the wires with the meter!
The later PSA cars use pretensioners mounted in the seat belt reel & not in the buckle like the earlier cars.
Also some of the plugs have a metal clip over the connector plug that will short the system to earth, shut it down & put the warning light on if the plug comes lose.
