Rear Window C5 Help
AtitudeJim
Rear Window C5 Help
Unread post by AtitudeJim »
since i bought the c5 estate, the rear windows doenst open on that button under the wiper blade, what can it be?
cheers
(04) Citroen C5 2.0 Hdi 110hp (uk)
(90) Pug 205 1.8D (uk)
(92) Vw Polo G40 (pt)
SandyD
Unread post by SandyD »
Hi, did you get a warranty with your car? As I’m on my second rear window from my dealer and it seams to be a common fault with the car.
Sandy. :?
AtitudeJim
the car was my company's ex-fleet at a "bargain" price so warranty... is not on
i dont know if it can be a blow fuse problem, or the lock is damaged or even just the switch.
PowerLee
Unread post by PowerLee »
If its the 2004 one in your signature then it will still be under Citroens 3 year warranty wont it?
406 V6
Unread post by 406 V6 »
Had the same problem with mine, and another person on this forum had it too.
Opne the boot lid, remove the trim. You will find a solenoid with a 3mm diameter steel rod or so goinfg up. Push it up to open the rear glass.
Take the plastic ocver out, on the inner side of the wiper blade and you will find a plug. Disconnect it for a few days (if it's not raining), and put everything back; Then make contact on the plug with the key and see if you hear the solenoid activating. If it works again, put some sealant around the (na zona de encaixe do conjunto do plático exterior, junto ao botão) - sorry, didn't remember this in english, guys - and assemble everything. I suspect it's a humidity problem that shorts the solenoid, and the prolonged "on" action put's it out of service.
Take care!
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
