C5 estate owners (a quick question).
user_3150
New User
Unread post by user_3150 »
At the tip today a C5 parked next to me and it had a switch in the boot with what looked like height settings displayed on it. You know a circle with a line through it at different heights. What does it do and why would you use it?
Kitch
Unread post by Kitch »
Maybe its a way to adjust the height of the car without having to expend energy walking round to the cabin?
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
bencowell
Unread post by bencowell »
To change the height of the car so you can put heavy loads in without breaking your back!
user_3150
New User
Cheers Ben seems to be a handy feature would anyone agree?
bencowell
It would be better if you could change the height from the keyfob.
fastandfurryous
x 4
Can you imaging the chaos that would happen if that went wrong?!?!
Nice idea in principle though.
This is not a signature.
406 V6
Unread post by 406 V6 »
Yes, that button is used to change the rear suspension heigth, to whatever height you want between the lowest and the highest position (these included) As such you have an infinit choice of height, not being limited to the 4 standard positions. Very handy, i usually choose the highest, or near, position when loading the supermarket groceries, as when they are heavy or many, the sinking is lower than on normal height; and ye, you won't break your back as much :P
Only problem is when the 12V accessories fuse blows, the button ceases to work :(:( (gotta get me a fuse...)
A remote function on the key fob would be nice, but only available for the next 30 seconds after opening/closing the car, as that's more than enough time to decide if we want it to stay as usual, or at another height.
Cheers!
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
If you do alter the cill height using the up/down switch at the boot door, the chosen level stays there for only a few minutes before automatically going back to normal height.
406 V6
It stays there until the boot lid is closed, or one of the doors is open/closed
Francisco
mezuk04
Unread post by mezuk04 »
I've never heard about such a feature for the C5, how handy would that be and the 'how cool is this' ranking would be sky high :P
Volkswagen Golf 59' 1.6TD S :(
SandyD
Unread post by SandyD »
Hi all just a quick link for C5 it shows the boot height adjustment of to a tee.
http://www.honestjohn.co.uk/road_tests/index.htm?id=23
Sandy. :D
406 V6
Unfortunately, only the estate has this feature :(, as this would be also a good solution the the hatchback, for when loading some heavy suitcases. i'm glad we have the estate :D
Francisco
NiSk
Unread post by NiSk »
Interesting language they use there, on Honest John:
"it's still over nearly 2 metres long" (referring to the lenght of the C5 luggage compartment)
I'm sure that style would go a long way with Mr. Plod . . . . "but I was only doing over NEARLY 70 mph".
Best report them Mr. Blairs language police!
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
AtitudeJim
Unread post by AtitudeJim »
406 V6 wrote:Unfortunately, only the estate has this feature :(, as this would be also a good solution the the hatchback, for when loading some heavy suitcases. i'm glad we have the estate :D
the estate has also the advantage to visually nicer than the saloon version :wink:
(04) Citroen C5 2.0 Hdi 110hp (uk)
(90) Pug 205 1.8D (uk)
(92) Vw Polo G40 (pt)
bencowell
While most hatchbacks may lack a rear wiper, once you are moving you don't notice it.
The estate rear window will pick up a lot of road dirt on damp motorways, but the saloon will always be as clean as an operating theatre!
