Bottom Rad Hose for 205 1.9 Gti
Natasha
Unread post by Natasha »
I've just been on the phone to GS&F Heathrow and they do not stock this part!! Any ideas where I can get it from as I had to hack mine off last night, and obviously really need to replace it!!
Any help supplied much appreciated.
N
Natasha
http://www.205gtidrivers.com/forum/
Natasha
Just spoken to a dealer and I'd have to order one as they are not stocked. No idea how long that might take!!
So much for me getting this sorted tomorrow. At this rate I'll have to make one!
Natasha
Edited by - Natasha on 06 Dec 2002 09:39:51
StuartR
Unread post by StuartR »
Hi there, if your desperate Halfords (probably others too) sell universal hoses. If you took your origonal one they could match it up. Not origonal but I bet it would last long enough, gti's are getting old now so probable out life the car now.
just a thought, Halfords are probably closed now though!
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Use two lengths of convoluted hose from Halfords and cut them to size. If I remember rightly the engine diameter is slightly larger than the rad outlet.
Dave Burns
x 3
Unread post by Dave Burns »
Check the rad connection isn't the modern plug in and "o" ring type, if it is I don't think the Halfords hose is an option.
Dave
Natasha
Eventually got the correct from another Pug dealer would be believe!
Fitted it, and it was fine for about 30 miles, when the system presurised (probably correctly for the first time in ages) and it blew my head gasket!! lol
It actually blew a hose, did a Cylinder Combustion test and yep it had gone. So now I am going to need a replacement!!
Natasha
