Radio Code every time?
Jshodgson
Unread post by Jshodgson »
Every time I turn on my ignition the radio asks for the Code. Does anyone have any ideas? Could this be linked to the problem I have with my steering wheel controls (the volume buttons don't always control the volume, they sometimes activate the memo function).
Ta
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
Stewart(oily)
x 35
Unread post by Stewart(oily) »
It sounds like you have lost the permanent live feed to the stereo, I had a similar problem with my ZX which miraaculously cured itself when I had thee steering column apart, probably a dodgy connection but where?
Stewart
x 1240
Unread post by Peter.N. »
I would concur. If you check the two 12v supplies to your radio, one will come live with the ignition, the other should be permamant. If you cant find the problem, wire it into a permanant supply somwhere i.e the cigarette lighter.
Robin
Unread post by Robin »
A few of the radio models available to Citroen and others gave you the option to programme the radio to seek the code before each operation. So if the live feed is present this may the cause.
If the live is there at all times then the radio will function with the key out of the ignition in the normal manner. Both of mine shut off after about 45 minutes in this mode. Robin
Citroens are dedicated to those who take a big bite - and just keep on chewing!
