clunk at the front
Jshodgson
clunk at the front
Unread post by Jshodgson »
When I pull away I notice a clunk coming fom the front of my car. I can almost feel it through the pedals I think. The only time it doesn't do it is if I pull away extremely slowly with lots of revs. It also appears if I jolt it into 2nd gear. I can't hear when I go over bumps (I had a saxo that had a similar problem and it turned out to be the suspension arm banging on the bottom of the car).
Any ideas? Need I worry? Anything obvious I should look for when next under it?
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
bxbodger
Unread post by bxbodger »
Get it on axle stands, get underneath and have a look at the rear engine mount- the round one from the back of the engine to the bottom of the bulkhead. The rubber disc is probably crumbling away.
Jshodgson
thanks I'll have a look at the weekend. If it needs replacing where can I get one and is it easy??
